- Sep 1, 2011
- Age
- 58
- Location
- Boston Ma.
- Website
- www.bostonharborcharters.com
- Boat Make
- 33 Flowers.
Sorry about so many pictures.
When I got my boat the previous owner had this 3 piece custom cover made for the boat (spent some crazy $ on it also)
I guess it worked for him but doesn't work for me.
I used it to cover the boat instead of shrink wrap at my house one winter but the covers haven't come out of the custom bags he had made for it also.
Big problem is the clips they drilled and installed thru bolted all the way around the boat and them catching fishing lines and gill nets.
1st pic shows the cover on, other pics show the clips & bolts/nuts.
I plan to remove all of them from inside the hull and lay some matt inside also.
Problem is hull is gray gelcoat.
I'm thinking of either filling from inside with with white gelcoat tinted gray and mix with cabosil to thicken and lay matt over inside
Or fill holes from inside, matt from inside then put about a 1/2 - 1 inch pin stripe all around the boat to hide the holes.
Transom makes no difference as I plan to fill & glass in all holes, old scuppers, livewell drains & awlgrip transom gray to match the rest of the hull.
Thoughts, ideas, suggestions ???
