samhop
- Sep 16, 2012
great forum, yes i searched and found some great info
been looking at replacing my wet log with a shaft tube for 3 reasons in order of importance
1 my hull came out of a 3 peace mold and the aft seem at the dead wood split from shoe to hull. i patched it up last year but it needs to be properly repaired.
2 i spun the bearing in my external bronze cutlass and the last time i changed it i bonded in the bearing with some hull and deck, it needs to be changed again which will require pulling the shaft and splitting the bearing to remove it.
3 increasing hull efficiency
my thinking might be FUBAR, but this is the plan; get a tube the same size as the hub in my bronze, milled internal aft to take cutlass and external forward for existing drip less . get a number from shaft center to shoe and hull at a fixed point. pull the 2" shaft grind/prep the front of existing log. on the dead wood im looking at cutting a slot but leaving a tab on the face of the deadwood to help maintain shaft alinement. grind out the old water feed holes and glass-er up.
do i need to pop the top on the log and glass inside to.
and do i leave the log as is or foam it.
my thinking is leave it and jest glass from the outside. our if i have open it make a water tight inspection hatch and not foam it.
OK so far?
what im trying to noodle out is reshaping the trailing edge if the dead wood. i assume it is better to keep the tapper fair and as far forward of the wheel as i can to increase water flow.
pics are all i have showing prop and external bearing any input would be helpful
thanks
OK so far?
thanks
