Meanwhile on Facebook...
chortle
Annapolis, MD
Holy S..t! Known cause? Looks like an old installation.
pugsley
it's because those john deeres have sooooooooooo much torque they rip steel sheets to shreds.
pugsley
but seriously, no gear mounts, so everytime you shift aren't you getting a little push/pull on that plate?
That is good stuff. Aluminum is pretty soft stuff even cast which the bellhousing looks to be. Odd that it would break in such a brittle fashion. Looks more like a broken cracker than bent metal. Makes me think some vibration fatigued the shit out of the metal for a long time and then it just gave under a particularly high load.
Dont leave us hanging Travis!
I would expect the edges to have a torn look here and there at least is all I was saying especially since the whole circular center piece came out.
Badlatitude
CT
We have grenaded a bunch of race trannys and engines. They always shatter. never seen cast bend
Keelboater
I see rear motor mounts holding up the back of the motor. I see the tranny sitting on the bottom of the boat. I don't see any tranny mounts that could have prevented this overhung load on the aluminum bellhousing. It must have been fatigue failure over a period of time, or maybe all at once during a grudge race?! The shaft had to move quite a bit when this happened. I can't see the shaft coupling or stuffing box. So what kept the boat from sinking? Any pics of her on the bottom? :-o
