Merging Fuel Lines
Fishonnelsons
Truro, Cape Cod
Www.bethanncharters.com
Rich
38 Wesmac, 29 Dyer
ccc
Thats the way we do it on all the Shamrocks except, fuel filter on each tank.
Yea, my Shamrock had the Groco 3-way valve for the 2 tanks and I thought that was by far the best way to do it. All functions in a single handle. If that’s what you’ve got, I‘d stick with it, personally.
My Sisu has at least 4 valves in there, maybe 6, to do the same thing.
ccc
Not to nitpick, but the ones Shamrock uses have 6 ports, so the return lines are switched, too. (2x ports for each connection - Tank 1, Tank 2 , out to engine.)
Quik Fix 16
Emerald Isle, N.C.
Shamrock
The older ones don't have return ports. Only FI engines had return lines. All Boynton and Wesmar built, the only ones I deal with , have no return lines.
Pequod
Shamrock 246 Open
My Mercruiser engine (5.7l Horizon MPI) does not have return lines.
Three way valve is used.
