Gene B
Prior owner had some issue with crystal-like debris clogging fuel line pick-up in the port side fiberglass fuel tank.
Debris never made it to the racor but would restrict fuel flow/cause rpm drop.
Best description of the matter was that it looked like diesel colored rock candy., that could be crushed between two fingers.
Two hand holes were cut in the tank, on either side of the tank baffle, and approximately a cup full of the matter was loosely scraped out of the tank bottom.
Tank is in good shape, no sign of deterioration at all. Pretty sure something went into the tank that layered and solidified on the tank bottom.
Picture of the debris is attached,; it's dried out now and easily breaking down into a powder.
Once the tank was cleaned, the engine runs fine, no drop of rpm either fuel tank.
The starboard tank has not been inspected.
Would be interested if anyone would venture a guess as to what the debris is.
Gene
Gene
