Nauset 35 Refit
LuSea
Clinton CT.
Tom
Nauset 35
LuSea
Clinton CT.
Tom
Nauset 35
LuSea
Clinton CT.
Tom
Nauset 35
xbskt
13 Whaler, 14 Salty Boats, 36 Northern Bay. WTF!?!
Am I correct that it looks like you laid the H Beam where it landed in 5200 and screwed through the flange? Shimmed with coosa pieces to lock in the height? Can you bond coosa or glass directly to the H Beam? Epoxy needed maybe if yes?.
Thanks for posting.
LuSea
Clinton CT.
Tom
Nauset 35
xbskt
Correct. These boats have a cockpit liner that was an integral part of the cored floor. The layup at the transition is about 1/2” . The original floor was laid as one large panel atop this ledge. We used three inch wide ledge to support the ends of the lateral beams. The Coosa blocks raised the beams the additional 3/4” we needed. We ground everything and bedded the Coosa and the beam ends in 5200 , screwing thru the bottom flange to sandwich everything until the 5200 cured … 4 days later. We coped the other end of the lateral beams into the main beams and used 2” angle and 5200 bolted , to make these connections. We used epoxy ( Thixo) on a few of the remaining lateral beams around hatches because we could wait for the 5200 cure time. We bonded the glassed floor panels to the beams with thickened epoxy. The 5200 bond is super strong but the cure time is painfully slow. The beam manufacturer says 5200 is an acceptable bonding material and fantastic for vibration as long as the beams are bolted as well . They said abrading with 36 grit and cleaning the surface of dust were important steps in the success of the bond. If I had to do it again I’d probably go the same route because the Thixo bond is very strong but the 5200 is just so flexible.
Thanks for that. I am still waiting for fiberglass rectangle tube for my Tripp project. I have it in my head to use these to raise the deck (and scuppers) but was surprised when told that even though they are called fiberglass you can't just set them in hull and deck nor will they allow tabbing them in with polyester resin. Is that because they are not really fiberglass? I haven't really looked into it but will figure out which way will work best for me. Construction adhesive is a top contender because that is the world I come from but their are many ways to skin this cat.
LuSea
Clinton CT.
Tom
Nauset 35
LuSea
Clinton CT.
Tom
Nauset 35
05bill
cape cod
rp, willis beal
4/9 Update:
- Old thru hulls have been patched.
- Faired the cockpit
- Built engine room intake and exhaust plenums with integrated fuel fills.
- Installed the sliders and windows for a test fit. To be removed for painting.
- cut and refit the Flybridge ladder
- added a teak header to retain the doors and a bit of nostalgic Nauset.
The butting ends of the sliders will have a bullnose interlocking teak astragal to accept the lock keeper and weatherstrip.
That’s it for the cockpit. On to the engine hatches and engine space!
amazing ! where did you get the hatches, i am assuming they were custom made ?
thanks
LuSea
Clinton CT.
Tom
Nauset 35
