Need a diesel mechanic close to Brooklyn NY, for John Deere 6081 engine, common rail fuel injection pump issues.
Anton Lee
Hello I have a 2006 6081 JD common rail engine . I need a diesel mechanic to check and if it’s the issue then change the fuel injection pump. I’m not sure if it’s the pump. It’s in 31 foot down east boat , I was cruising and it stole while on the way . The computer on the panel says no fuel at the rail , prime the system and restart the engine . I’ve done it 3 time with no success! The fuel tanks are full!
No water , no air in the system . No lines are clogged the fuel flows easily to the pump Ive checked. If you know a diesel mechanic that can help , please share his contact.my number is (718) 902-8544 Anton Thank you.
Not near you but try calling Herman at
Ocean Power
Point Pleasant Beach, NJ · (732) 295-0400
super good guys at that shop.
Reelman955
South Shore Long Island
Roy
New Boat 2015 24 Seaway w/115 Mercury Command Thrust/ Old Boat-2007 28 Seaworthy/BHM 315 Yanmar
Heavy Duty Systems 262 South Ketcham Ave Amityville NY 631 923-3223 Ask for AJ. I've had nothing but great experiences. They do mobile service too. Not cheap but fair. Shows up when he says he will and if he's running late he will call. Stands 100% behind his work.
Anton Lee
Thank you very much! I’ve called them , they are pretty busy now….
