Hello I have a 2006 6081 JD common rail engine . I need a diesel mechanic to check and if it’s the issue then change the fuel injection pump. I’m not sure if it’s the pump. It’s in 31 foot down east boat , I was cruising and it stole while on the way . The computer on the panel says no fuel at the rail , prime the system and restart the engine . I’ve done it 3 time with no success! The fuel tanks are full!
No water , no air in the system . No lines are clogged the fuel flows easily to the pump Ive checked. If you know a diesel mechanic that can help , please share his contact.(My number is (718) 902-8544 ) Thank you.
