NEW BHM hulls
Captlvb
Forked River, NJ
www.missbarnegatlight.com
235 Kencraft
Just curious who has the BHM molds? It seems like they are quite popular today with the downeast crowd yet you don't hear about new hulls. Does Atlantic Boats still have them and choose not to use them?
Crabman
My 36' has a draft of 3' 10". She's spent the tide hard on her keel many times with no ill effects except for not being able to get out of the slip. Very easy to blow out the bottom around the boat for more depth if the slip is the only concern.
Captlvb
Forked River, NJ
235 Kencraft
Thanks guys. Wish the slip was the only issue. The slip has about 5 feet but the lagoon (creek) we have t go down to get to open water has a few low spots. It is mud so I figure with the keel if we only BUMP we could push our way through. There are times in the fall on a spring tide and hard NW we get a blowout tide and we just aint getting out.
Crabman
I've got the same problem in my creek especially during the winter which is our main crabbing time. The mouth of the canal has a bump of hard sand I have to cross. During times of hard NW winds, the water is blown out of the bay and I have to grind my way across the sand to get into the canal. A handful of times, I've had to leave the boat until the tide comes back in. I have a sacrificial piece of starboard screwed to the last six feet of keel to protect the fiberglass from wearing out. The boat is tough. We have actually laid her on her side a bit as we ground our way in or out.
If you have mud, you shouldn't have too much problem. Repeated trips will blow a path through the mud or you can just grind through it. I have had days where I had to sit it out until the blow is over and the tide returns. You aren't much different in NJ as we are in NY, one or two days of severe low tide and then the recovery begins and it's usually in the winter.
HarborRd
I think ABC will build a BHM if you want one. It's been mentioned on here before that on the "recently launched" section of their site there is a 36' BHM that was a somewhate recent build.
Super Suck
New England
Lasco 5' fiberglass
drafts vary, I just checked the doc stats of several BHM's I know of, it ranges from 3.5' to 7.1' with a lot @6.5'
