Apparently this product is no longer produced, figured I just post it in case anyone (other than me) was thinking of using it as a core material. I was going to use it to replace my deck, looked like a great alternative to foam or balsa. Bummer.
Contacted a dealer (www.apdmro.com) that does all things 3M and their responses were:
a)"3M decided to discontinue the entire line of composites except for a couple compounds. The sheets are no longer available, and therefore not on our site any longer."
and
b) "3M actually discontinued their Nida-Core line, the entire plant that manufactured them in Port St. Lucie, Florida has been closed down".
I guess another example of a corporate acquisition that did not work out. Looked like a decent product, and at a price point much more attractive than Nomex et al. Will need to investigate the Canacore option and see if they have a distribution channel here out west.
Dave
In my opinion, a better alternative to NidaCore is a product called Canacore. You can purchased Canacore from Fiberlay . I've used both products, they look, feel, cut, etc exactly the same, however the Canacore is much stiffer in the raw form which makes it easier to use. You can get Canacore in 4x8 sheets in thickness from 1/2" - 1 1/2". I also read online, that the rumor is that Nidacore will continue to be produced by a different owner- I have no way of verifying that, just read it online.
Balsa core
Reccomendations for thickness and layup? I was thinking about 3/4" core with 1 layer of 18oz roving and 1 layer of mat on each side. I know that some of the sailboats (27-30 foot) around here use this for their hulls.
I don't know what size your deck is, but I go with 1" Canacore for my decks, and I use 2 layers of 1708 with a layer of mat on the top side and 1 layer of 1708 and a layer of mat for the bottom side. I go with 2 layers on the top side for more strength and more puncture resistance. A 1" 4x8 sheet of Canacore is only 2-3 pounds more per sheet than the 3/4".
From my undestanding its to create a I-Beam of sorts with the core acting like the web of the beam and the skins being flange like to spread the load, and that some strength comes from the space between the two flange faces. My understanding, but I'm and Electrician.... I'll leave it at that.![]()
