Non skid replacement
Discussion in 'Downeast Projects and Boat Building' started by mike@mpi, Apr 17, 2019.
  1. mike@mpi
    mike@mpi Senior Member
    Sep 1, 2013
    283
    106
    stevensville, md.
    26 JC
    The forward deck on my JC had a non skid texture that was molded into the gelcoat. It held up well but the boat's over 30 years old and it's worn almost smooth and is now dangerously slippery. I was hoping for some suggestions on redoing it. I'd like to use something that uses vinyl or polyester resin because that's material I've used a lot and am familiar with. When I rebuilt the boat years ago I finished the cockpit deck in grey gelcoat with added in play sand and it worked well and has held up over 10 seasons. But I don't think it will look nice up on a white forward deck. Any recommendations would be great. Thanks
  2. F/V KRISTA MARIE
    F/V KRISTA MARIE Member
    Feb 4, 2015
    78
    15
    Stamford
    General Marine 26
    I really like this product
  3. jdickau484
    jdickau484 Senior Member
    Nov 25, 2012
    439
    512
    Ninigret Pond, RI
    For my non-skid, i thickened gelcoat with cabosil and rolled it on with a nap roller.
  4. starrfish
    starrfish Senior Member
    235
    86
    nantucket ma
    35 duffy
    awl grip makes white non skid, i use a blend of medium and fine. mix it in with the gelcoat..
  5. BHC.com
    BHC.com Senior Member
    Aug 8, 2017
    122
    28
    I 2nd this.
    Nothing last forever but this method is easy to sand/prep the next time around.
    I had a deck that was gelcoat mixed with black beauty (sand blasting abrasive)
    That a nightmare when it came time to redo !
  6. mike@mpi
    Sep 1, 2013
    283
    106
    stevensville, md.
    26 JC
    Thanks, that's the look I was going for. For the pattern around the forward bitt, just mask it off? And like you said , the old pattern on my boat just needs a light sanding which is easy. No real material to remove.
  7. ForTUNAte Son
    ForTUNAte Son Member
    Aug 24, 2016
    35
    6
    That looks great. Do you happen to remember how much cabosil you added to the gel coat?
  8. CCtuna
    CCtuna Captain
    Oct 20, 2012
    723
    221
    Nauset
    Some day...
    I’m curious as well. Surprised you were able to get that much texture with the cabosil
  9. jdickau484
    Nov 25, 2012
    439
    512
    Ninigret Pond, RI
    Yes, Mike.
    Not sure exactly, on how much cabosil I used. I usually just mix a hand full in at a time. For non skid, i like to see the gel get noticeably thicker but still a far ways from a peanut butter like consistency. Couple clearer shots of the texture. the bugs were dive bombing that night lol.
  10. MikesMarine22
    MikesMarine22 Senior Member
    Oct 21, 2011
    371
    184
    Marine Mechanic
    Mass
    I've also used Kiwi grip roller to texture gel coat.
    sailor of fortune likes this.
  11. ForTUNAte Son
    Aug 24, 2016
    35
    6
    So you've simply rolled gel coat, then rolled with Kiwi grip roller to create nonskid texture? No application of griptex or nonskid additive, just gel coat?
  12. CCtuna
    CCtuna Captain
    Oct 20, 2012
    723
    221
    Nauset
    Some day...
    That is an extremely impressive tape job
    Genius and jdickau484 like this.
  13. powderpro
    powderpro Captain
    Dec 3, 2011
    2,895
    1,973
    The Ocean
    O'Neil
    Good looking, nice job
    jdickau484 likes this.
  14. MikesMarine22
    Oct 21, 2011
    371
    184
    Marine Mechanic
    Mass
    Yeah. I have applied with 3/8 nap to coat and then the last coat I go over with the kiwi grip roller. If you wait until it starts to set up you'll get a more aggressive pattern
    ForTUNAte Son likes this.
  15. RCLS2016
    RCLS2016 Senior Member
    Jan 11, 2016
    125
    44
    Maintenance Tech
    NJ
    26 SISU
    I spoke with Joe from Mertons. He suggested the cabosil & gelcoat method as well. He sent me all the stuff to do it at a very reasonable price. 2nd for prep/refinish for the next time. I am going thru 2 layers of epoxy paint, a 3rd layer of paint, and a layer of gel coat. 2 of the layers have sand in them. That SH$! is tearing up everything I throw at it. I'll be posting pictures of my progress as soon as I make some. Lol
  16. mike@mpi
    Sep 1, 2013
    283
    106
    stevensville, md.
    26 JC
    That looks great jd. Exactly like I was looking for. My second post I forgot that it was BHC that mentioned that abrasive additives are terrible to remove later which is so true and I hope RCL shows more pictures of his project.
    How did you make those perfect radiuses (radiei?) , curves , in the masking. I couldn't freehand that. Trace around something that has the right curve? Pictures are great ,nice work, big help.
  17. jdickau484
    Nov 25, 2012
    439
    512
    Ninigret Pond, RI
    Traced a mojority of the radiuses and did freehand some of the irregular corners. Easier than you would think though. The little imperfections hide pretty well in the non skid.
  18. Brainey
    Brainey Senior Member
    Aug 29, 2013
    459
    136
    Manager - Environment, Safety and Health Departmen
    VA Beach VA
    43' Atkinson
    For the radius I saw a guy use a quarter and a razor blade - worked well.
  19. MikesMarine22
    Oct 21, 2011
    371
    184
    Marine Mechanic
    Mass
    I usually use a big fender washer but yes same idea.
  20. south shore
    south shore Senior Member
    Aug 19, 2012
    368
    248
    Millwright/Mechanic/Retired
    Bay Shore, New York
    25 Northern Bay
    jdickau484 was the first coat of gel coat waxed
    white waxed gel coat first then tape off scuff or sand and dewax and do the second coat waxed gel coat caposil mix ?
