Northstar 952X antenna advise needed
I have 2 antenna's that connect to my 952X, one is a square shaped antenna with the numbers AN205-P gps/beacon antenna printed on it
The other is a pie plate shaped antenna with Aero Antenna Technologies Inc
At 7530 1NW printed on it.
The unit plays fine with both antennas hooked up to it but if i unhook one of them(forgot which one) i lose the differential signal. So how much accuracy am i losing by not using the diff beacon signal?? Last year i didn't even have the antennas mounted on the roof i just laid them on the dashboard behind my electronics and everything worked fine. I don't want to have to drill 2 holes in the roof to run the wires so can i run and be safe/accurate with only using one antenna. If i need to run both how close to each other can they be? I thought to mount them on a T shaped mount and then could have both on one fold down mount.
The two antennas
you can just see the antennas behind the 952
Capt. Rick
Long Beach, NY
31 RP Willis Beal
Steve, guess nobody knows..... I love the 952 but have always used the 952x, no experience with the DX. If you like, try calling TOM at Starboard Marine here on Long Island, NY.... 516-764-1224 or 800-645-6541.He will def. know the answer. Warning - he is a character and a half. With regard to your second question, as far as i know, as long as the antenna can "See" the sky, you can put them close together, it shouldnt effect anything. Good Luck with it.
I called Northstar(Simrad) in New Hampsha' and got the answers i needed. I'm using the square antenna and since i don't know what my cabin layout will be like after i get around to building the split house i just put a big glob of hot melt glue on the top of the antenna and glued it to the ceiling :D above the plotter! I turned it on and let it play all day and it tracked like 6-8 satellites all day and never lost the signal. Hope it stays stuck up there for the season. Thanks for your reply.
Sounds easier than the gps antenna I was playing with last night
Takes ages to get a fix
