Norton Project
Discussion in 'Downeast Projects and Boat Building' started by CapeCodNorton, Oct 13, 2015.
  1. CapeCodNorton
    CapeCodNorton Senior Member
    Sep 6, 2015
    130
    69
    Firefighter/Paramedic Hyannis Fire Department
    Yarmouth Port, MA
    23 Crowley Beal
    I purchased a 1974 Norton last month as a project. It was seaworthy so I finished out my rec lobster season and had several fun days on the boat with my wife and three boys as well as some other guests. It is powered by a 2005 Honda 90 and I get 25-27 knots WOT. It also has a 10" Hydroslave hauler.
    I started tearing it down the other day and I'm now 7 hours into it. here are a few shots of my progress thus far. I also did two drawings of my ideas of what I want the boat to be. I took a ton of measurements off the boat and drew these up as 1mm = 1inch so everything is proportional according to my measurements, I really like both honestly but I am leaning toward the open design. I will likely replace the gunwales, which were balsa sandwich construction and totally rotted out, with coosa and the cabin will be divinycell for weight savings.
    Bill likes this.
  2. JimRP31
    JimRP31 Captain
    Oct 21, 2011
    1,124
    261
    Sales
    tiverton RI
    Willis Beal/RP 31
    Good luck on the project. I like the closed design good sun and water protection. IMHO
  3. Keelboater
    Keelboater Captain
    4,406
    2,269
    I second the enclosed version, providing it's feasible. What is the overall length? Is it an 18? That would be small for adding the top. Good luck with it and be sure to keep us updated on progress.
  4. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    The boat is 18'6 with 6'8 beam. I've been wavering between both designs for a while. I would love the top ultimately but don't want it to look goofy. I tried to keep the lines of the cabin elongated and the windshield and top narrow so they don't draw the eye upward and give that chunky feeling. The plan is to build a mockup out of some strapping and get a better idea of overall looks.
  5. South Shore Boatworks
    South Shore Boatworks Captain
    Oct 28, 2011
    508
    245
    pilothouse
    I think that it will look good with the pilothouse. I would put more rake in the windshield and front of the trunk cabin. Something like 15-20 degrees. You will know when it looks right. We are working in Harwich 2-3 days a week on a 50' Brownell sportfisher. I would be happy to stop by for a look
    winterking likes this.
  6. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    That would be great, I'd love to bounce some ideas off you, I'll PM you my address
  7. Toolate
    Toolate Captain
    5,331
    1,439
    Building contractor
    Think you mean 1 cm = 1"? Nitpicking I know..
    I had a 21 seaway with a similar layout and it was ok (soft top not hard) but I cant see it any smaller. Post a pic when you mock it up- love this idea.
  8. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    1 mm on my paper is the equivalent of 1 inch of boat length/height. That was the easiest best way for me to scale it down and get an idea of proportions. My head room is limited to 5'10 on the sides and I'll add 2-3 inches of crown. I'm 5-9 so I'll be cutting it close for sure. I'm not making the final decision until the mock up is build, I'm still in demolition mode. Between hauler, fuel tank, cuddy cabin, gunwales and deck and stringers I've removed 1200 lbs from the hull. The deck/stringers were 3/4 ply and saturated with water. I'm hoping to keep it around 600 or 700 lbs when I add everything back using the composites and converting the hauler to an electric motor.
  9. Jangles
    Jangles Senior Member
    Jun 19, 2013
    197
    30
    Northport, ME
    I would consider a 2-3" pitch on the cabin top, in that 60"(?) length from aft to forward. I think the pitch would disappear to the eye, would keep the leading edge of the cabin at bow level, the windows the same size, gain a couple inches of headroom, and as an added bonus shed rain water. That would make your dash 42-43" high, same as bar-top in kitchens, which I don't think is too high. You've got the steering will on top of 40" right now, that I think is too tall, and should consider a vertical mount wheel.
  10. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Transom
    Got to work on the transom finally today. It took a little while to get through all the layers. It was made up of 5 layers of end grain balsa all glassed in between and a large piece of mahogany to fill the cutout for the outboard. The original transom is designed for a 20" shaft so I'm assuming this was done when the 90 hp motor was put on. It was about half rotted and the rest was very wet. I left the original outer skin on because it is curved and i wanted to keep that feature.
    My next step is to sand everything and get down to glass. the paint on the inner hull is very tough and hardly seems phased by 60 grit on my random orbital. Thinking Ill try stripper next.
    Jangles, I hear you with the height concern of the wheel. I plan on mounting it a 20-30 degree angle, this should lower it a few inches. I really want to have the helm and hauler inline so I can move the door for the berth to the center. Thats the design idea right now, but I'm staying really fluid with all of this so whatever truly works Ill go with.
    Any suggestions on stripper to use? Also, I'm thinking of keeping the original 20" transom which would put my antiventilation plate about 3" below the hull. I know displacement hulls can handle lower mountings and benefit with increased manueverabilty, is this too low for my hull design if I'm not overly concerned about drag?
  11. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Project updates
    After getting the boat down to just the original hull I wrapped her up for the winter and waited for the weather to turn again in the spring. I was able get back to her at the end of march and have been plugging away steadily in an effort to get it launched mid July. My self imposed deadline was the 16th and I'm happy to say I nearly made that deadline. It looks like Ill be in by the end of this week. The boat is not totally complete but I tried to focus on the things I needed to make her underway.
    Here are photo updates, I need to finish framing the windows and connect the electronics this week.
  12. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Pics
    More pictures
    1 person likes this.
  13. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Pics
    More Pictures
    5 people like this.
  14. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Pics
    more pictures
  15. Keelboater
    Keelboater Captain
    4,406
    2,269
    That looks great! Nice job! What did you paint it with?
  16. crabz
    crabz Senior Member
    Nov 2, 2015
    344
    113
    commercial fisherman
    Alaska
    All American
    Excellent work!
  17. Eastporter
    Eastporter Captain
    2,564
    583
    Super transformation! I love the built in transom seating/storage. Excellent use of space. Are you going with a marine canvas sun visor?
  18. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Thanks, I used Jametowns Wetedge flag blue and white
  19. CapeCodNorton
    Sep 6, 2015
    130
    69
    Yarmouth Port, MA
    23 Crowley Beal
    Thank you, I wasn't planning on it, Ill still be fishing my traps with it so I wanted to keep the gunwales clear. The next part of the project is going to be the v-berth down below so my kids will have a shaded retreat if need be.
  20. South Shore Boatworks
    Oct 28, 2011
    508
    245
    Norton
    It is hard to believe that your Norton is the same boat that we saw last fall. The proportions of the windshield and trunk cabin are perfect. You did a great job.
