Oil Level HOT or COLD ?
CsBreeze
1977, Bruno Stillman 35
So I have a mid 70s Perkins, 6M354T in my Bruno 35.
Should I be checking the oil cold (when it reads hi) or hot (when it reads low)
:confused:
- & I looked in the manual & it only says how much of what, and when.
Thanks !
<a new guy>
Nighthawk
Portsmouth, RI
Carolina Classic
Most manuals call for cold because you should be checking the level before you start the engine. That said you shouldn't be seeing that much of a difference solely due to oil temperature. After shut down, make sure you are allowing enough time for all the oil to make it back to the pan.
CsBreeze
Oil or Not !
Well at least that's a reasonable opinion !
& yes, it & others on that "once u'r aboard" checklist
-- Thanks
