Opinions on 16ft Staford Dory Skiff
Discussion in 'Skiffs and Small Work Boats' started by Diesel Jerry, Jun 21, 2018.
  1. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    3,911
    1,926
    What do you guys think? What is the most HP anybody has ever put on one?
    Strafford skiff
    He still has it and comes with trailer.
  2. Old Mud
    Old Mud Captain
    3,767
    2,927
    Retired Fisherman
    Jerry, i put a 40 on one and it was way to much. Real squrily at wot. ended up with a 25 and that was just right. Probably ok for the LB races though, just don't hit a wake at wot. :)
    BOSBoatMan likes this.
  3. Toolate
    Toolate Captain
    5,438
    1,491
    Building contractor
    Had a flat bottom lapstrake job like that and 28spl was the ticket. More and she rode up on a chine which was fun but not safe really. Riding around at a 45* angle...
    Old Mud likes this.
  4. tsharac
    tsharac Member
    May 9, 2012
    6
    I have a Stratford dory with a 40 HP Honda tiller; the transom came with a 1/4" thick contraption that straddles the transom. Gets up to 28 mph with me solo. We've used it for tubing a few times. It's my favorite boat; been 5+ miles offshore, but mostly use it for fluke fishing in shallow water I can't get much else into aside from a canoe. The plywood floor and transom rotted out, so I replaced both with Nida-Core (solid fiberglass resin where the outboard bolts through the transom).
  5. BOSBoatMan
    BOSBoatMan Captain
    Jul 25, 2012
    3,094
    981
    Quincy, MA
    1992 Nauset Bridgedeck Cummins 6BTA & 1995 GW Escape 175 Yamaha & 2013 Carolina Skiff J12 25 Yamaha
    I had one. In fact sold it to a fellow YC member and it’s probably in his backyard in Quincy MA
    He would probably let it go for chump change if you want it let me know.
    Had an 8 hp Nissan two smoke she’d do 17 mph with that then a 9.9 Yamaha 4S I only lost 6 mph with the weight that obviously turned me off to four strokes
    Curmudgeon likes this.
  6. BOSBoatMan
    BOSBoatMan Captain
    Jul 25, 2012
    3,094
    981
    Quincy, MA
    PS
    Photographers
    DJ
    LMFAO guys hilarious
  7. ErikT
    ErikT Senior Member
    Sep 7, 2011
    261
    277
    New York
    Crowley Beal 28
    I had a 15 Sturdy Dory, with a 35hp 2 stroke tiller that was too fast. 25 was the ticket for mine. A fun boat that could handle some weather that I should not have been out in... as long as you went slow enough it got you home.
  8. spygull
    spygull Member
    Oct 12, 2011
    43
    25
    Had a 16 ft. Stur-dee dory for years. rigged with a side console radio and fishfinder. My kids first real boat. had a 30 hp Evenrude on it same weight as the 25 so I figured why not. With 1 person and light load would go 35 mph but became hard to control. with a heavy load the extra hp was handy when running our south shore inlets. 25 hp was probably ideal.
  9. Big Joe
    Big Joe Member
    Mar 15, 2017
    84
    29
    Petroleum Dealer
    Snug Harbor R.I.
    22' Sisu
    I have a Stratford Dory with a 20 Yamaha 4stroke. The motor can’t have more then 30 we’ll kept hours. Boat has some rot in The transom. I made aluminum engine plates and caps. I would let it go for what the motor is worth. Also has a trailer
  10. Recoil Rob
    Recoil Rob New Member
    Jul 30, 2018
    I've had a SturdeeBoat Amesbury 16 with side console since 1996. The first few years I used it with an Evinrude tiller 15, it was OK. In 2000 I went for a new Honda 25 with the remote control.
    One day, here on LI Sound, Norwalk Harbor was like glass so, with another adult on board, I opened it up. Right around 34-35 mph I could feel the air between the skegs lifting the boat up so I backed down.
    With 400 lbs of fishermen and 200 lbs of gear, ice and coolers the 25 will still drive it at 25mph, just takes a bit longer to get on plane.
