That’s all??Slow acetone wipe.
yep.
Then wax it.
Do you follow the heat gun with the 303 or you saying wipe it throughout the season to protect?use a Heat gun and it will turn from white to black as you watch, then wipe occasionally with 303 UV Protection.https://www.amazon.com/303-30313-CSR-Protectant-Plastic-Fiberglass/dp/B00KN0UOEE
You can also wet sand it with 400 grit then 600 grit wet/dry sandpaper then again use the UV Protection
Sounds like an easy solution. I will give it a try. Thanks and I’ll take a Budweiser lolYou can use just the heat gun. But I would wipe it with the 303 throughout the year to keep it from oxidizing and turning white. I use the 303 on my car's black plastic trim and wheel flaps.
If all I gotta do is run a heat gun on it, I don’t mind it being a spring maintenance item.Also, out of the two methods I have used, the one that takes the most labor last the longest, (sanding with wet or dry). Of course!
Make sure it is an "industrial strength" heat gun like this, Master Appliance HG-301D Master Heat Gun 300-500 Degree-MAHGIf all I gotta do is run a heat gun on it, I don’t mind it being a spring maintenance item.
