Merritt Marine Supply. ATC Poly-Fair F26 Fairing Compound 5-Gallon PN# F26
http://www.lbifiberglass.com/FAIRCOMPFILL/faircomp.html#660
System Three QuikFair Fairing Compound
Got a bit of fairing to do on my 25 TJ. Specifically on the hull,it has pock marks from traps on the stbd side along with dings and dangs in a few other places.. I wanted to see if anyone had reviews on LBI fairing compound as it is much cheaper than polyfair. Also am I going about this the correct way in terms of the pock marks?
for fairing board paper , what do you guys use? 3M?
I just bought this fairing board.. it will do the trick right? there are different flexes? point me in correct direction if not
http://www.ebay.com/itm/3m-sanding-block-30-long-Stikit-style-rigid-part-83497-marine-fairing-board-/300942017467?viewitem=&sspagename=ADME%3AB%3AEOIBSA%3AUS%3A3160&item=300942017467&vxp=mtr&nma=true&si=txb%252FSmHGBjGbVU1Rd89QZZGz02Y%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557#ht_26wt_1045
