Prop try outs .
Robert M
Gloucester MA
Wanna play with a few props without dropping 2g on them. Anybody know where I can borrow a 24" x24 4 blade with a 2" bore.
Robert M
Gloucester MA
Talked to a few guys both said might be a better fit then my 23" 25 pitch
Robert M
Gloucester MA
This is my wheel now. I have the room to go bigger. My boats getting dropped in and getting hauled at another yard I figured it would be a good time to play with 1 different prop size. Can't hurt. I'm open to any suggestions , props are like flux capacitators to me.
Robert M
Gloucester MA
Wow that's a small hub on that one
All I can tell you is that it's a 2" bore that's made it 12 yrs. other then that I don't know much about props. Have room for a bigger and the ponies, just don't know what the hell I'm doing. Or if it will even be worth it. Just figured I would play having a free haul in all.
Let's photo tach the motor with the
reconditioned prop.
When you going in and "moving" the boat ????
Robert M
Gloucester MA
reconditioned prop.
Not for a bit , but the motor is getting a going through by a cummins cert . I just wanted to play, and maybe have a spare.
Robert M
Gloucester MA
There are many props for sale on the net , same size, same bore. Just curious why is this strange.
Hub wall tappers from 1/2 " to 5/8" .
Robert M
Gloucester MA
No , no worries at all, just trying to learn. Why does hub size matter? 5/8 wall on a 2" bore is small?
Robert M
Gloucester MA
Is this a better pic? I'm looking at L 24" 24 props on the net for around 1,900. A lot cheaper then local shops. What's the theory ?
MASTERENEGADE
NORTHPORT
Had a DE, now 24' Privateer
Currently im swinging a 23x23x2" bore so dont feel bad.
Im actually gonna buy a new prop 23x22x2 with a lil cup. Currently i have no cup and have cavitation.
Finding small props like this with a 2"bore is a bitch. Thats why now that im done playing with props and know exactly what i need, im gonna buy brand new. Capt larry found me a 24x24x2 that i tried and then shaved down to the current size.
Good luck with the search.
Robert M
Gloucester MA
Thanks for the info, I just don't know a lot about props.
I haven't found it a prob finding props for this size.
This may seem stupid but there's a lot of used dual props sold in this size.
Why wouldn't the Left turn prop 24" be the same?
with the bigger hp motors being put into smaller hulls , why would a 2" bore be that strange with a smaller diameter prop?
Love the knowledge here, thanks in advance.
MASTERENEGADE
NORTHPORT
Depending on the transmission, you can reverse it to swing a lh prop. Which maybe the direction im leaning towards when i go to make the purchase of a new prop.
For my low horsepower(320). Every tells me i have a beefy shaft(no pun intended) so your guess is as good as mine.
Whats size are you looking for?
Powderpro
The Ocean
www.oneilboats.com
O'Neil
Robert- I figured First Team was being sarcastic when he said that was an odd size prop, but he must have been serious. I have seen, installed, and used numerous 24" diameter props with 2" shafts, doesn't seem odd at all to me, actually my experience would say that is a somewhat common sizing. Here is a pic of a gillnetter I built in 2011 that had a 24"x24" Michigan prop with 2" shaft.
