petrel
I have a 56' DMR w/ twin 671 TI's. Gears are 2.5 to 1, but the shafts are only 2 inch. The boat has always had 28x34 4 blade wheels, according to the previous owner, who bought it from Dwight. I figured there were a couple of reasons f/ being so over-square. One being marginal shaft size and the other being speed because of the reduction (would seem to be more ideal around 2 to 1 w/ a 28 square?) My prop guys says the blade area on the wheels I have is slightly less than 70% and I would benefit from going to a wheel w/ about 80% blade area if I understood him correctly. He says there will be some top end loss of of speed, but it should be better efficiency for cruise speeds. Current top end is 19 or 20 knots at 2300, cruising 13 to 15 knots at 1700 to 2000 depending on conditions, load, etc. The new wheels we are talking about are the ZF's. I'm curious to hear from others who might have made a similar change w/ blade area. Theoretically, it should save a little fuel, possibly enough to pay for a set over the season?
