- Sep 1, 2011
- Boat Make
Question for the prop/DE hull experts on the forum.
Maybe no perfect answer to my question.
Assume two identical DE boats. Let's assume the hull is the builder's 33 footer.
The prop aperture of the hull can accommodate up to a 28" prop with standard accepted clearance.
Each is the same weight, 14,000 lbs.
Each has the same engine, 480 hp, rated 3300
2.5:1 gear with a 2" prop shaft
Cruising rpms for recreational use 2600 rpm.
Prop calculator suggests a 4 blade 26X31 prop or the equivalent
4 blade 28X28
rule of thumb........assume 1" of diameter equals 2.5" of pitch.
rule of thumb the 26X31 is the equivalent of 28X28
solid cruise speed is of most importance, not wot speed.
I've heard from builders and long time DE owners that a 4 blade square prop is "best" for a keel boat.
I've heard from builders and long time DE owners that the square prop being "best" for a keel boat is a myth.
Which prop would you choose?
FWIW,
Bill D
4 blade 28X28
FWIW,
Bill D
