i have a couple questions. after many years with outboards last year i bought my first imboard. a 28' ellis flybridge. it was a bit of a learning curve. it has a fiberglass rudder if iswap it with a stainless one will it help? backing into the slip? it has a right hand wheel will swapping to a left help? helm is on the right. power is a volvo tamd41p hs1 200hp. shaft size 1.5" prop 18x16 rh. top speed 15kt @3950. i have been told the volvo trans can be run either direction that true? it would seem to me it would be better to have the prop turn the same direction as the engine or dose it matter? also was told motor should turn 3800rpm if so would one inch of pitich do it? last question anybody have a lh wheel laying around?
