- Sep 1, 2011
- Location
- MA
- Boat Make
- Sold- 20' Eastporter (Rebuilt 2011) 22' Pearson Ensign
I am wondering if anyone can answer these questions (builders). Thanks.
1) Do you have to remove (grind off) glass to seam the two sides of the transom together after removing from the mold (two sides back to one in the mold)? To make it flush, or do you glass over the butt joint and then remove some of your core material?
2) If you are building an open transomed boat for a fishery do you need to make the hull thicker or add knees/structural supports etc. to compensate?
