I was checking out a 28 northern bay . Doesn't have enough headroom . Could anyone tell me what it takes to raise that roof approx. 6" . Could make the difference on buying, or not.
simple job. like Travis posted its mostly planing.
i dont like the jest raise the top method.
my preference is to raise the house.
pull the windows and cut where the front meets the trunk, around side at console level, then step down the bulkhead if needed to get to window level and go under the windows leaving the radius so the bottoms become the base tine. If the winter back windows are at a different level or there are none throw in another step it makes it helps keeping things lined up. the widows should fit right back in. you can add a strong back/hand grab, between the window and where your cuts end or door.
layout table, make up what you need and glass it in. you will gain a little on your console if it makes a step you don't wont chop that out and change it
take a look at top angle some NB's drop back as they go aft, now is the time to change anything you feel like you need to.
as to time 4 or 5 days if Mr Murphy is not to involved
jest my 2cent
