jrg
What's everyone using to rebed deck hardware?
I have some rail stanchions that are leaking into the cabin and a cleat that's leaking into an aft locker. Should be a quick spring project, but looking for some guidance. Thanks.
Before rebedding, I would check the coring around the bolt holes. You are likely to find saturation and if so, you should consider using drill w/ bent nail to clear out the rot. Fill with epoxy and when it has set drill out the hole. Consider using butyl rubber as your sealant.
I swiss cheesed the top of my T Jason existing 1/4,20 holes with a 1" hole saw NOT drilling through the bottom hole.
Scraped out all the dead/dissolved balsa...most was dry...and will fill with hull & deck or a resin/cabosil/chopped glass concoction filling in under the lip and re-drill for hardware, antennas, radar stuff etc.
FWIW
I am dealing with the same issues and plan on starting this work next weekend. Any recommendations for loosening up 5200, 4200, etc... I am planning to use boat life for re-fitting, thoughts.
Opsrey... thanks for the nail idea.
Thanks!
MT
Excellent advice. That coring is wet for sure. I use an allen key as apposed to a bent nail. The sharp edges of the allen key make short work of the core. Once decored tape the inside of the one and pack the old hole with H&D putty, pushing it into the void. Re bed I am a 5200 man.Before rebedding, I would check the coring around the bolt holes. You are likely to find saturation and if so, you should consider using drill w/ bent nail to clear out the rot. Fill with epoxy and when it has set drill out the hole. Consider using butyl rubber as your sealant.
Thanks!
MT
