I am repowering my TJ 28. 6BT to 6LPA. I am also changing all the running gear (increasing shaft size).
I am doing most of the work myself and this project is a little bigger than anything I have done before, but not by too much.
My question is one of timing or procedure. Here is my plan.
Remove old engine. (done)
Dry fit new engine (rework engine beds as necessary) to old running gear.
Rremove old running gear and install new.
Final fit and adjustment.
Done.
My thought is that by leaving the old running gear in it will give me a reference point to work with for lining up the new engine.
The engine is soft mounted so I should be able to adjust for any minor misalignment that creeps in during shaft replacement.
Ok let me have it! Am I going about this the wrong way?
Done.
