parke.brinkley
- Oct 19, 2011
I have moved out of state & need to sell this boat. I'll sell the hull alone for $5750, or everything for $16.500. Here are the details:
2006 ROS 24 commercial hull
Self-bailing
deck cap glassed to the hull with heavy-duty rub rail overtop
1/2" thick acrylic windsheild
Wide washboards with 20" drop in shearline from bow to stern
Has been kept on a lift until this past summer
Bottom painted with Interlux Micron Extra CSC ablative paint (red)
2006 Yamaha F225 4-stroke, approx. 369 hours (maybe 269, but I have to check the gauge to see), launched November, 2006
Properly maintained- upper & lower unit oil, water pump & impeller all changed this past spring
2 square Yamaha smart gauges (fuel management & speed/tach)
2 aluminum props, extra nut/thrust washer, etc
Morse stainless steel control w/separate trim/tilt switch & starter key
SeaStar hydraulic steering
$300 Gemlux 3-spoke stainless steering wheel with suicide knob
ICOM VHF
Lowrance sonar/GPS/chartplotter with Navionics gold chip
55 gal fuel tank under the console- stainless fuel fill
20x30" stainless/aluminum diamond plate deck hatch in cockpit
3/4" bronze thru-hull with seacock under the deck hatch (not hooked up to anything)
6 Gemlux cast stainless rod holders on the washboards
Hawse pipes at the transom with cleats mounted underneath
Stainless mooring bit on the bow deck
LED nav lights
8-breaker switch panel- good quality from blue seas
All tinned copper marine wiring
2 batteries (cranking & deep cycle) with switch under console
1500 gph Rule bilge pump
Boat was used for recreational fishing only & is named the Ms. Addie. Original owner. Call Parke at 205-381-648Four if you're interested.
Self-bailing
ICOM VHF
LED nav lights
