Rosborough 22 Inboard Wheel Size
JSousa003
Bermuda
This is my first post, but have been following many threads and learning lots from everyone's builds & projects.
Over the past year I have repowered a Rosborough Sea Skiff 22 with a Yanmar 4JH4-HTE 110hp inboard. The current wheel I'm turning is a 16x17RH with a #4 pitch (-0.63). I am currently able to turn 3500 RPM at full throttle and the motor is designed to turn 3200 RPM.
I have been advised to change the wheel to a 16x20RH with a #3 pitch. What do you all think about the wheel size & the suggestion?
Thanks for all your help in advance.
Sailorgp
Great Lakes
Sisu 26
vou've been advised to make an awfully big change to your wheel in order to drop your wot a slight 300rpm. I'd go with a 16x18 wheel which would theoretically put you at 3300 wot rpm. Being 100 rpm over propped is actually good for your engine.
JSousa003
Bermuda
Thanks for the input. After discussions with Michigan Wheel I settled on a 16x19 with no cupping. Still about 150rpms over when fully loaded with gear, but I can live with that and hopefully once the coolers are full of fish that will be helpful.
