- Sep 1, 2011
- Boat Make
- 25 Terry Jason with Cummins 370 power
Hello all,
I know a few of you have used Seahawk paints and I've read Rampage88s thread when he did the bottom of his 32.
Milton up @ Hamiltons in Portland told me one "2 gallon kit" would be plenty of paint for two coats of barrier coat on my 25 T Jason. Does his estimate sound correct. Should I buy two "2 gallon kits" "just in case? I don't want to run short.
Also I plan on two coats of black water based anti-fouling after the barrier coat.
What do you figure....one gallon or two ?????
The bottom of the boat is bead blasted, clean and will be wiped with Acetone. The bottom feels nice and "rough" after the glass blasting last fall.
Thanks for any info,
Bill D
Bill D
