wiggy
Thought I'd post a pic of my progress. I've removed the rotten stringers and next week after some more grinding and cleaning I'll be adding a chop mat and 1808 before adding two 4"x10" foam stringers from Prisma. The plan then is to re-deck with more glass and coosa. I'm also converting the transom back to a outboard notch. The previous owner converted the boat to an inboard but did a really poor job so I've decided to go back to an outboard. I'm debating replacing the transom with coosa, sort of a "while-I'm-in-there" situation. I don't see a lot of rot but the idea of there being no wood left in the boat is very appealing. I'll post some more pics when I start glassing and installing the foam stringers. Compsys (the people that make Prisma) have been really great to deal with and their product seems like it will be cheaper and easier to use than Coosa stringers and only a few more dollars than marine ply when you consider the glass lay-up costs. After the glasswork is done, my winter project is to make a teak windshield in the woodshop. Anyone know if theres a bass boat windshield pattern out there? There are a few more pics in my folder if you're interested.
