Seems like a deal
BTW, is there or has there ever been a fogging "oil" for diesels??
Jonathon
It's hard to make any kinds of assurances like that. Ideally you'd home the engine was turned over by hand fairly frequently. If you're real serious about buying the boat, but also real concerned out the engine, you could pop out the injectors and borescope the cylinders.
It would be a gamble I’m not sure I like the odds at 50/50 - cause you don’t know for sure till ya turn the key ......
turning it over good advise I’m sure that make a difference
slow troller
Fortier 26
looking for opinions, cost to finish boat for launch? I know there is a number of if this and if that
However assuming motor checks out , I have reached out to seller No response
also sage advice please
Motor may carry a full warranty once signed off by Cummins tech.
BSEA
Bow thruster install, boot stripe, spray rails, cored panels for bulkheads, lotta' hints that someone had some good ideas. Provided the weather didn't damage anything sounds like a nice start. It will be interesting to hear comments once someone goes aboard.
Snake8
Its local to me, if anyone from afar wants someone to look it over hit me up. Can anyone tell what Beal it is? Calvin Im thinking at 13'9" beam
