shaft brush grounding strap
james
brunswick ga
crusader 34
you can make you own grounding strap with a brush you can buy at most local napa auto parts or parts shops i make mine with a piece of 1/2 or 3/4 copper tubing hammer it flat on an anvil epoxy the brush to the end and saulder the wire lead of the brush to the grounding strap or straight to the connecting wire it is simple and cheap to do frees you up from having to order them and will save you some money i have about 3 bucks tied up in mine hope this is helpfull i use high strenght hard set epoxy you can pick that up most hardware stores
