backman
Not to hijack the other prop thread with this but having broken 2 shafts in my previous boat, a 17,000# Carolina Classic 28 I'm a practical expert. That boat had 1.5" shafts and mathematically had a safety factor of 5.
While it was as solid and well built a sport fish out there, the entire Carolina classic community was constantly breaking shafts, more often in the northeast than in the Carolina's. The majority of the breakages were in the 1000 hour range and were from continual pounding at planing speed for long periods of time, over and over and over. I broke one at 600 hrs and another at 1100 hrs and had to replace another with a crack at 800 hrs. I had to dye test the shafts every year to be safe. Breaking a shaft offshore in a twin screw boat sucks, but you will get home at 6 knots eventually. 13 hrs from west Atlantis as an example!
this is a good summary to start from:
http://www.wbmetals.com/downloader.asp?filename=Aqualoy_Brochure.pdf
I learned the hard way about a factory safety factor of 5 really being a safety factor of 3 when you factored in things like short 3.5" hubs, where the hub actually sits on the taper and the effects of high torque and continual steep chop on a shaft over time. Lapping the hub onto the shaft , properly torquing the 2 nuts tight as well as minimizing the hub to bearing distance was critical in that boat setup.
So - now that I'm in a downeast and pretty much eliminated those pounding 21 knot rides forever - is shaft cracking and breakage something I need to be aware of and monitor by dye testing annually or is it a non issue in a properly designed set of running gear.
