Shaft-Flange alignment
sandytows
When aligning the engine how many thousanths is acceptable?
Soft mounted engine if it matters?
Keelboater
I was taught that .003" is the maximum allowable angular misalignment between coupling faces. This is for vibration isolating mounts.
oldshell55
new york
BHM36 , 38’ young bros ,
1/1000th per inch of diameter of coupling max on solid what I was taught
although you shoot for 0 up/down and side/side it ain't easy, find 0 then loose it trying to get it in the opposing , always close but no cigar is "commercially acceptable"
New installation or existing engine? Not that it matters just curious what you are facing.
chortle
Annapolis, MD
Dave Gerr recommends .001 per inch of coupling flange diameter, so a 4" flange would be .004".
