I was just curious as to how hard it was to install a shaft log. Figure if you had the alignment done already. Anyone have experience with this as i know this must require it. How is shaft angle determined, is it worked back from the prop going to route that you want the biggest prop at the lowest angle then figure which gear applies and then that dictates where the engine sits. I know they always want the engine as far back possible but what truly dictates that.
Just sitting here dreaming how de boats are made...
