Shaft sizing..
Got my shaft out of my 25 t Jason and it's all scored where the packing was.. I don't have room to move it forward or aft so looks like I'll be finding a new one.. Right now it's 1.5" x8ft.. I'm running a 2:1 gear with a 240 yanmar .. From what I'm told ill prob be going with a 20x21 wheel.. Any input on this? Should I go with another 1.5" or is a 1 3/8 ok? I'm not sure if I'm going back with the old stuffing box with a new cutlass or going to frp tube with a cutlass machined into it .. I'm gonna run up to h&h tomorrow if I have time but figured id get some input on here..like everything else new to all this
Why would you go smaller? Just curious why you are even thinking of downsizing?
Bill,
When we "sized" the the shaft for the Cummins 370 ZF63A 1.54:1 gear 1.5" shaft was suitable. The shaft on my install is 102".
I decided to go OVERKILL with a 1.75" shaft. The boat will be swinging a 20"X20" prop.
I'd stay with a 1.5" shaft on your setup.
Bill D
Keelboater
Bill, what is the rated rpm of the motor? Divide that by your reduction ratio to get shaft rpm. Using Aquamet 22 material? Then use 70,000 psi torsional shear.
[(321,000 x 240 hp x3) / (70,000 x shaft rpm)] ^ 1/3 power
You should find that 1 1/2" dia. is sufficient. I took a guess at 3400 motor rpm and came up with 1.247" dia. (say 1 1/4" dia.). This includes a safety factor of 3 which is commonly used. This is for strength only and does not take into account the length.
Max bearing spacing:
[(3.21 x 1.5")/(1700 rpm)]^1/2 power x [mod. of elasticity/shaft density]^1/4 power.
For aquamet 22 I get a max shaft bearing spacing of about 5.27 feet if you go with a 1 1/2" shaft. I'm sure there will be comments made on this number. It is what it is according to Dave Gerr.
Thanks appreciate it.. Oh i wasn't looking to downsize. I had someone who had a 1 3/8 shaft sitting around... I'm gonna make a few calls today.. One thing I was told is there is no other way to go besides that aquamet 22..keelboater.. Thanks for that bearing spacing reminder. I have about 6ft of unsupported length so 1.5 it is
