tashmoo2
A guy with two engines can limp home on one if the other breaks down.
What can the single screw guy do other than call for help?
I've seen expensive back up sytems advertised for around $20k. $20k pays for more than a few tows back from canyons. It seems to me that there should be a way to turn the shaft using a generator for power and an electric motor or hydraulic motor if the boat has hydraulics. Only problem might be turning gear in neutral for extended period of time. Why hasn't someone come up with a simple system?
