Bumping an old thread. I have to install a rub rail and thought I would ask how it went JK? Also need some advice on how to handle the corners and bow bends. Rail has a hard plastic piece molded into it and its going to be a bitch to bend even with heat I think the lip on top will fold upwards
With a heat gun you should not have any problem bending the rail.
Did you bed the whole rail in Sika or just a bead down the side of the boat to hold it?
I ran a heavy bead of Black Sika on the rail 2-3 feet at time before I screwed it on. Mine is black semi rigid from Barbour. Going to try to attach pic of it.
Also have existing holes in the boat I would like to re-use from the old #12 or #14 screws.
I would fill in the old holes. Getting them to line up will be tougher than it sounds. Plus you can smooth out the edge if there are any cracks etc. I used West Six10 and it worked very well.
This is the rail
Item Number: 62160/F758
Was going to start by laying the rail on hot driveway for an hour or so, cleaning hull/deck joint and caulking with Sika or Sudbury stuff Travis recommends (great stuff but running out) heating and creating a bend for the bow, and starting there with the idea that I could end with a joint on the center of the transom or miters at corners.
Center your bow rail on the boat and mark the center. You do not want to drill a whole at the center since it will open up when you bent it. Make a mark 8" from the center on either side. This will be your first two screws. Then mark the rail every 18". I pre-drilled all the holes with a counter sink bit, drill the last hole on each end 6" from the end. Their is too much build up to drill them on the boat. Once you have drilled the rail hang it from the boat with string, this will reduce the weight and make it easier to handle. I attached the rail and then cut the string and pulled it out.
Put some Sika on the rail from the center out past the first two holes on either side of the bow. Heat the rail and have a friend on either side bend it slowly around the bow. You will not have to force it. Then screw it to the boat with the first four holes. Then heat and follow it down each side putting enough Sika to cover 3-4 holes but only screw down the first 3, this will give you space to add more Sika as you go. Do not screw the last hole into the boat. You need some wiggle to butt the next rail.
Follow the same steps as above but make sure the new side rail is touching the bow rail tight a little overlap is ok. Put Sika from the bow end 2-3', skip the first hold and screw holes two and three. Once this is done, grab the bow rail and side rail pull them from the boat and snap them together. This will give you a very tight joint. Then screw the ends down, repeat on the other side. Use the same method for the stern piece. I am assuming you will use 4 rails total.
Then work my way back. Have a friend hold tension while I drill and screw a few feet at a time using a bead of caulk at top and bottom of the rail so its really held down.
I would not put the Sika top and bottom. Put enough on the center of the rail so the Sika will squeeze out top and bottom.
Is this too much caulk?
No such thing as too much Tips for corners?
Heat them and don't force it to bend. Would love some help and maybe apicture of a corner someone has done with the lip over the deck.
