sold my Outboard Motorboat and dont need these Outboard Motor Parts:
WickedGoodOutdoors.com
Make me an Offer for ALL of these parts. I want them out of my basement! Most parts are Brand new and a few are used.
all the Outboard Motor parts came form a closed repair shop down in Mass)
I'm in Saco Maine but can ship this stuff. Or if you want to buy it all bring a Truck!
Alum Propeller 14X19 #176215 fits Johnson/Evenrude New! Just $100.
LOWRANCE Blue water Pro Flasher/Paper chart recorder Fishfinder
with transducer Just $150.
Teleflex throttle/shift CABLES for Merc/Mariner Just $1 per foot.
Also have a dozen brand new Teleflex shift & throttle cables in the boxes for Johnson/Evenrude Just $1 per foot
Factory & Aftermarket Marine Outboard Motor Repair Manuals (used) $10 each
Recoil Starter Assembly and factory service manual for Merc/Force 9.9 or 15HP outboard motor. Asking $80.
A remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor. $40. It will most likly fit others
4 Big heavy Alum wedge Brackets to shim up outboard bothers on your transom for better Hole Shots! Just $50 per pair
Brand New Valves for Inflateable Boats. $25 Each
Stainless Steel Steering arms for outboards Just $25 each
Tilt Pins Bars for Johnson/Evenrudes Just $10 each
Teleflex 18-3056 Impeller Dia. 3 1/2",Dpth. 1 1/4" 6 Fins NeopreFits Honda 75 to 150 and Mercs and others. Just$16 .each three for $45.
TRIM TAB 327640 OMC JOHNSON EVINRUDE used Excellent Cond $25. Each
New Parts for OMCs JOHNSON 85,90, outboards.
3 each #323664 Spline Gear $99.ea.
1 Ea Ignition Coil Kit # 583737 $99.ea.
1 Ea Voltage Regulator Kit # 173640 $189.ea.
2 Ea Helical Lower unit Gear sets 340490 $199.set
2 Ea Rubber Exhaust Gaskets $10. ea
1 Ea Complete 90 Hp Gasket set # 139300 $50.ea.
6 Ea Gaskets # 317914 $6 ea.
2 Ea used OMC Stator #583669, #583672, $50 ea.
1 Ea VRO Kit Part # 438406 includes Pump #175161 $250 ea.
1 Ea Timer Base Kit #583376 $99.
1 Ea New Rectifier/Regulator Kit # 395391 $135.
1 Ea Used Rectifier/Regulator # 395391 $85.
1 Ea Gasket # 359-317955-1 $6.ea
9 Ea Gaskets # 194-321727-1 $6ea
5 Ea Gasket # 2Ea
Gasket # 436-323459-1 $6.ea
4 ea 90HP Rod Bearings $50. set
2 Ea Ignition coils #582508-0560-0A $99. Ea
1 Ea Stator $100.
1 Ea Flywheel $100.
ACCELL Distributor & Rotors Caps for Mallory $18. set.
Felpro Chevy 305/350 4 boat rubber valve cover gaskets 1 pair PN# VS12869R New $10.
Felpro Chevy 305/350 Cork/rubber valve cover gasket 1each New. $4
NEA PN# VS2335 Chevy 305/350 4 boat Marine Exhaust Manifold gaskets. New. 1 pair . $12.
Felpro Mercrusier Chevy 305/350 Gasket kit assorted not complete (head gasket missing) $10..
Bronze 11/2 Prop Nut $3.
Johnson 90hp lower unit Gasket #286279-2
Teleflex Black 15ft t shift/throttle cable OMC new 1 ea. $15.
Teleflex Black 23 ft shift/throttle cable MERC new 1 ea $25.
Teleflex Marine Trident Blue Wet Exhaust Hose 3 dia X 50 lg. $50. .
(SOME USED STUFF)
Johnson Shift/Throttle control Housing $40
2 ea Johnson 90 HP upper metal housings $50.ea
3 ea Johnson 90 HP Lower Unit Housings $50.ea
1 Ea Johnson 90 HP fiberglass cowlings. $50. Ea
1Ea Lower plastic cover for Johnson 90 HP $50.
3 Each Motor mount Brackets with serial #s for Johnson 90 Hp $150.Ea.
Recoil Starter Assembly and Shop Service Manual for
Asking $99.
Two Power tilt motors for older OMC I/O outdrive. Unknown condition. $40 for both
5 Ea Gasket # 2Ea
1 Ea Stator $100.
1 Ea Flywheel $100.
Heavy Battery Cables Just $1. per foot
Make me an Offer for some or the WHOLE LOT!
Parts and Repair Manuals:
Chevy/GMC 5.7ltr Serpintine Belt. New never used $25.
Johnson/Evenrude Manuals $10.
Raytheon Marine Electronics Factory Service Marine set of 2 $20.
Chilton Chevy/GMC Full Size Trucks 1988-1993 Repair Manual $10.
Chiltons Subaru 1970 to 1982 service manual $10.
ACCELL High Voltage Ignition Coil New in Box $50.
ACCELL Chevy 350 mallory dist cap & rotor new $10.
Chevy 350 Complete engine gasket set minus head gaskets $10.
Valve cover gaskets for Chevy 350 $5.
Perfect Circle Vale for Chevy 350 $5.
Set of vale stem seals for Chevy 350 $10.
Oil Filters for Chevy 350/305 $2 ea
Fuel filter Chevy 350 $5.
Universal Joint for Chevy full size pickup truck $10.
AC Spark Plugs R44T $6 pack
Gasket Set for Holly 650 Marine Carb $20
Set of Mallory Duel Points for Mallory Marine Dist $25.
will consider trades of new items like New Motorcycles, New 4x4 ATVs, New 4-5hp 4 stroke outboard motor. Firearms, New Woodsplitter, New 80- 130 class fishing reels make me an offer. Cash or Gold works well also.
[email protected]
I hope you don't mind but i posted your list on a Alaskan outdoors forum thinking some of the guys up here might be interested in your stuff. If you don't want it listed here just say so and i will remove it.
Steve
