Offering here with high hopes of avoiding the indignity of CL or FB marketplace. For sale is a like new, used 2 or 3 times in fresh water, year 2000 Zodiac Mk1 inflatable. Has roll up aluminum floor. Purchased as part of a package a couple of years ago. Never even unpacked it. Have previous registration and Bill of Sale. Last registered in NH in 2019. Asking $750 . All offers considered. Here is the description from the internet:
The product of over 70 years of experience, the CLASSIC retains all the qualities that built ZODIAC’s™ reputation: safety, stability and strength. Very easy to manoeuvre, it also has generous seating. Thanks to its inflatable hull and buoyancy tube, performance is optimised, planing is rapid and stability improved.
In the boot or on the roof of your car, you can take the CLASSIC anywhere. It can also be set up or put away in just a few simple steps. High quality that will appeal to fishermen and pleasure trip fans alike. It’s the ideal first boat.
Hull
Dimensions (m-fi)
Capacity
Aluminium / Solid
Dimensions of the folded boat (m-fi)
Outboard data
Hull
- Quick-fit aluminum floor with tie-down rail system
- Inflatable hull
- Aluminum motor mounting plate
- 2 bailers
- Buoyancy tube
- Strongan™ Duotex™ 2 x 1100 decitex fabric
- Easy Push valves
- Polyamid lacing cuff + safety grab lines
- Wide anti-chafing deflector strip
- 1 bow handle
- 4 carrying handles
- 2 stainless steel tow rings
- Cone reinforcers
- Fabric
- PVC thermobonded
- Standard Equipment
- Removable bow bag
- Fittings for remote steering bar
- Fittings for launching wheels
- Mast and pennant
- 2 carrying bags
- 2 paddles
- Foot pump
- 1 pressure gauge
- Repair kits
- Owner’s manual
Dimensions (m-fi)
Length overall | 3.50 – 11’6” |
Inside length | 2.30 – 7’7” |
Width overall | 1.61 – 5’3” |
Inside width | 0.77 – 2’6” |
Tube diametre | 0.42 – 1’5” |
Aluminium / Solid
Passengers (ISO) | 5 |
Max payload allowed (Cat C) (Hp – kW) | 590 – 1301 |
Max payload allowed (Cat B) (Hp – kW) | – |
Total weight (kg – lbs) | 64 – 141 / 61 – 134 |
Airtight compartments | 3 + 1 |
Length of 1st bag | 1,3 – 4’3″ |
Width of 1st bag | 0,6 – 1’12” |
Height of 1st bag | 0,35 – 1’2″ |
Length of 2nd bag | 0,89 – 2’11” |
Width of 2nd bag / Height of 2nd bag | 0,6 – 1’12” / 0,14 – 0’6″ |
Shaft | Short (15″) |
Min recommended power (Hp – kW) | 6 – 5 |
Max recommended power (Hp – kW) | 20 – 15 |
Max power allowed (Hp – kW) | 25 – 19 |
Max speed (Km/h – mph) | 45 – 28 |
