Spectra or mono for GS main line?
Badlatitude
CT
Jerry Brown makes 1000lb white hollow core spectra. Is this a viable option for a main line?
Downeastless
Should be an interesting debate...
I think for the price I will stick to mono, also for the abrasion resistance and how easily it is to change out.
I imagine you only mean for the backing which to me, still cheaper to fill it with the larger diameter mono and replace...
Jay c
31' Duffy
Zero stretch with a hydraulic bandit reel sounds like a bad idea to me.
petrel
NC
56' DMR, 31' BHM
Hey, you could use the plastic spool, lol.
Cr bound
Yes... I would say that as a backing Hollow core will be an excellent option. At some point you need to use mono to get some stretch. If it were my set up I would use heavy 3.0 mono and transition to 2.0 mono. Then use a swivel to connect my 2.0 mono to my spectra via a spliced loop in the spectra to an offshore swivel knot.
I think between your Break away and the general stress of trolling the stick on the line will lead to alot of break offs in the main line or worse yet equipment failure.
petrel
NC
56' DMR, 31' BHM
I'm not a greensticker, but 2.0 mono seems light for a mainline. That's like 400#.
hntrss
Oceanside NY
31 Duffy
I'm not a greensticker either, but I don't think the clips would stay in position at all on Spectra- toooo slippery. And Spectra will screw you up way worse than mono in case of some kind of catastrophic failure. Shit will cut you in half
Cr bound
I think if you made spliced spectra loops in the main line you could connect you drops to that.
Spectra is hollow will not cut you like braid which is solid.
petrel
NC
56' DMR, 31' BHM
Won't cut you my ass. Spectra is braid, braid is spectra. Some is hollow and some is solid. I'm about to go THT here. :mad:
