Okay, so first off I know this isn't a perfect spot to put a post about a spotlight but figuring they have a circuit board in them I will put it here...
I have a ACR RL-75 that I need to replace as the vertical motor is shot. Not sure if i can just grab the motor and install it but some of the plastic casing is worn and new light is only $225. Anyone ever go try replacing the little servo motor? Sadly its probably one of those things that the sum of the unit is 10 times as much as a new one.
Then comes location. Right now its located on the mast which is perfect in a sense. Problem one is I can't put the HD Radar up there because its to low now. He had a big 4' array spinning over it which was fine for him. Right now I just located the radar ontop for the fall to get her home. I want to return her to the top of the old mount.
So now I need to move this light.
We'll in an ideal world I would have a welder put one bracket ontop of radar on the mast, another landing. Not having a great luck in doing that and afraid if I have to pay for a retail welder, I will pay through the roof. I was thinking of even doing the fabrication work myself so then the guy just needs to pop up there and lay about 12" of bead or hell just tab it in.
I know its aluminum and I have ZERO experience with it. If it was steel, besides being a rusted mess I'd do it. Part of me was almost wondering about buying a cheap MIG unit with the crappy flux in wire bit and just tabbing it up there as I have a sheet of 6061. Then of course returning the unit, lol. Bad mojo there...
How much do you think it would cost to get this job done?
Then I was thinking about putting a lip under the light, on that frame, so I would not get any glare back on the bow. Have people done that?
Then of course, the last option is to just mount the light on the bow as a GOOGAN but wouldn't have to worry about alot of things minus earlier corrision...
Jesus, what happened with my cropping...
