SS Rudder Paint are leave bare
Robert M
Gloucester MA
Got a ss rudder, was going to wire wheel it clean, whats the idea about painting ? See some that are and some that aren't.
Robert M
Gloucester MA
You could also wax it, just an idea
Wax? Boat gets used twice a week in the summer , I guess its not that importaint , just didnt want to get it all shinny with the wire wheel and then slap paint on it, if I didnt have to.
Robert,Pettit zinc barrier coat....in a spray can...works great
Robert M
Gloucester MA
ill probable get it nice and clean and give her a spray. Thank you
Robert M
Gloucester MA
I wish they still made that clear anti critter spray paint I used for years on my outboards. Dont know why interlux stopped making clear?
I plan on trying prop speed this season. My rudder gets worms and barnacles, not to much on my wheel though.
greg
Point Judith, RI
Prop speed is a pita to reapply, and you do need to reapply.
I use the petit zinc paint on my metal running gear. Seems to work well.
Don't use a copper based paint though, it will not be happy against a dissimilar metal.
I think you will be very happy with the results of the prop speed but as stated it is a PIA to apply and expensive. I have had good luck with the Pettit zinc spray on the rudder. For 15 bucks it is well worth it.
mattinri
Full time cruising
Nordhavn 46
I had similar questions. Is there any downsideto using the paint on the prop? It seems much easier than propspeed which requires you to get the metal up to a warm temp.
I use wax on the prop and use the boat enough not to get any growth, based on your use I would think you would be fine too. But if you do use it on the prop just give it a light spray.
I have never heard of waxing a prop before. Regular hull wax or something different?
I use the same Collinite that i use on the hull.
To paint or not to paint I am not sure, however make sure it well bonded into your system to protect your propeller. I do agree that if you do paint copper base is not a good idea.
Get a mask and scrub brush and just jump in the water once in a while and scrub it.
Some guys near me do a "downeast haul out" a few times a year and scrub the bottom and running gear at low tide.
