Steering problem
Discussion in 'Downeast Boat General Discussion' started by Nick t, Sep 13, 2019 at 8:50 PM.
  1. Nick t
    Nick t New Member
    Friday
    Hi all
    Just bought a 35 duffy with power steering running off a hydroslave and the steering gets really hot and stiff as I run the boat any ideas what I could be
  2. Dslpwr
    Dslpwr Senior Member
    Mar 27, 2014
    340
    338
    Sales and service
    Columbia Falls
    Hydrualics’s are getting hot, need to install a cooler to solve the problem
    Diesel Jerry likes this.
  3. WoundUpMarine
    WoundUpMarine Captain
    3,462
    1,619
    Boothbay, Maine
    26 Duffy, 14 Holland
    Make sure the hydrualic tank is full as well.
  4. El Mar
    El Mar Captain
    6,806
    2,511
    All of the above, maybe add a bigger tank too if it’s undersized.
    strikecharters likes this.
  5. traditions
    traditions Captain
    Oct 9, 2011
    1,172
    330
    38 Holland
    Make sure the steering wheel can move in and out in the mount , not bound up, make sure to keep it greased, this can cause problems. They tend to run hot, and if you have one tank for a hauler and steering, adding a cooler will help both. I had a boat that had separate tanks, and the helm was hot to the touch, and the oil would turn black. Never had any other issues with it, and I had the boat for 13,000 hours. Is the pump pully driven? Sometimes a smaller pulley to slow down the oil . If you have a lot of 90's in the system, they cause heat.
  6. Nick t
    Nick t New Member
    Friday
    Thanks for all of the help there is a separate Pump and tank for the steering the pump for the steering runs off of the reverse gear when I first start running the boat it’s nice and easy then starts to stiffen up the longer I run it
    The wheel doesn’t seem to move in and out of the mount much
  7. Nick t
    Nick t New Member
    Friday
    How full should the tank be and what kind of fluid should I use ?
  8. Dslpwr
    Mar 27, 2014
    340
    338
    Sales and service
    Columbia Falls
    We use synthetic ATF here and should be 6-8 inches down from the top of the tank.
    Blitzen likes this.
  9. Cape Island Boats
    Cape Island Boats Member
    Sep 5, 2011
    51
    34
    Orleans, MA
    Couple of things to check. First make sure that when you turn the wheel and then take your hands off it that it makes just a little wiggle. if that shaft in the helm is binding up at all it means that helm is still trying to be on so to speak. Makes a ton of heat that way. Also look at the filter where return fluid goes back to tank and make sure the arrow on top is pointing the right way. That really heats them up too. If the pump is anything bigger than a v-10 its more than it needs. It should have a cooler too- we put one in every system. They are a great system when things are right with them, you should be able to leave your hand on the helm and have it just a little warm.
    sailor of fortune and Blitzen like this.
  10. Lion's Paw
    Lion's Paw Senior Member
    Mar 31, 2012
    155
    42
    Frisco, NC
    42 Duffy
    If you have the wrong fluid in the system it may also get hot and not perform well.
    My Duffy also has belt driven system like a hydroslave but made by Downeast Marine Engineering, but they no longer market this system. They should because they are excellent helm units. It uses hydro fluid like you put in hydraulic driven construction equipment, very slippery stuff, and a 10+ gallon tank that I keep about 2/3 full. The helm units will be warm to the touch after running but not hot and it never gets harder to operate.
  11. BillD
    BillD Captain
    5,997
    1,672
    Business owner
    the new to me 27 H&H has a belt driven pump, 3 gal. tank and 1.5 turn lock-lock helm pump.
    Hydroslave, 1997 vintage, 2100 hrs on the 6BT 210.
    Power steering is new to me. I'm learning. Thanks for all the good info !
