Been fine tuning this before I go drilling. Got it pretty close now.
First odd thing I ran into was although everything was seemingly lined up perfectly true, the cutout on the tie rod end was able to catch on the tiller arm when the cylinder was fully compressed.
A couple washers between the tie rod end and tiller raise it up enough so the possibility is alleviated.
Don't get why all standard stuff mounted with care would do this but options seem to be basically add a spacer (washers), grind material away from things, or mount the cylinder higher at such an angle that it prevents contact.
Thanks in advance!
Thanks in advance!
