STUFFING BOX-Rudder
tomy
36 Wayne Beal
water leaking by rudder stuffing box! I need to repack, but never had to do rudder one before, Is it same as main engine stuffing box? how do I measure for correct flax packing? thanks Tomy:???:
Should be exactly the same method. Yarn out the old stuff, throw in the new, tighten and have fun. Just wrap your packing around the shaft and carefully cut with a razor blade.
Or you could do the down east trick and put in a grease fitting
More people need to step into the 21st century
Awesome stuff man, awesome stuff
Glasses right into your hull, nothing to corrode, nothing to loosen, nothing that requires more packing and constant attention
tomy
36 Wayne Beal
Thanks guys!
1st...interesting stuff....are those for "new" cnstruction only, or can you retrofit rudder already installed?...thanks Tommy
