tailhook
Who has what and why? I was thinking on going with a dripless then I read up and possibly I might go with conventional
(1-3/4 shaft with wet tube)
Are they water fed from the motor? the only ones I can find are the big money tournament ones.Go with a self aligning two bolt gland type. Easiest to service. Just need a 9/16 wrench. Buck algonquin makes a very nice one.
Buck Algonquin?
I'd slide a Tides unit on if it was mine, your shaft is already out after all. If you're going to repack it use that graphite infused stuff.
