Tachometer inconsistent reading
seavee capt
I've been getting an inconsistent reading from my Yanmar tach which is connected to a 4lha engine. Any thoughts on where to look first? Grounding, sending unit and tach cable have been what I would think, but I haven't yet looked under the proverbial hood yet.
Toro
CT
19 Pointer
check all pins on the engine end of the tach wire first.
Pedlyr
Southern RI
Many tachs have a little dial type reostat in the back. You set them to your engine with a little screw driver until you get the proper detente. Sometimes they can get corroded. Just dial it around a few times with the screw driver and return it to the original position.
It could even be in the wrong detente position if it never worked right.
On the starboard side of the motor is the sender. It reads off of the flywheel. Find the sender down very low. Clean both the contacts & you should be fine. It is an easy fix and a common problem.
