Testing GPS
Brainey
VA Beach VA
43' Atkinson
Please pardon what is probably a stupid question - I'm making a deal on a used Furuno 1650 GPS, removed from a local boat. I want to test it to make sure it powers up and appears to work normally. Can I connect it directly to a car batter to test (assuming the correct fuses are in place)?
plowin
Newbury
33' flowers
Yes you can. Put an chip in it and plug the antenna in, ler er rip.
Run it for a couple hours to be sure ir does not shut down.
Pretty bullet proof units though, you should be fine.
duffy42
gps
You will get a better picture of the ability of the unit if you put it in your vehicle, pull 12 volts off the cigarette lighter, and go for a ride.
Gps doesnt say too much at rest, going down the road you can check speed, and heading.
Duffy42:)
