Through hull what should I look for
shoker
Should I be suspect of anything here? What should I look for as far as any water damage?
Sailorgp
Great Lakes
Sisu 26
It appears to be a high quality, properly installed seacock. Make sure the valve is not frozen and the handle turns smoothly. What kind of water damage would there be?
Look on the outside for pink metal.
Tuna Pursuit
Beverly ma
www.oliverwelding.com
Thunnus
Looks pretty clean. Are you concerned with the absorption pads. Probably there to catch any oil that might spill or drip or is there another part to the story.
Keelboater
How about bonding? I don't see a bonding wire in the picture. That could lead to corrosion if there are electrical issues.
Excellent pick-up The fitting should be tied into the bonding system. Also is the hull cored? If so was the surrounding area treated properly so that the filling is mounted in solid fill and not compressing core.
shoker
Great find, was so concerned about other stuff completely overlooked it. You guys are the best.
