Tolerenace for Propeller Shaft Alignment
Discussion in 'Downeast Engine Room' started by PatrickPresti, Jun 10, 2019.
  1. PatrickPresti
    PatrickPresti Captain
    May 2, 2013
    710
    54
    Ferry Captain/Mechanic
    Islip, NY
    Hi Guys,
    What's the tolerance specifications for a propeller shaft to transmission coupler alignment?
    Thanks,
    Pat
  2. Genius
    2,357
    1,139
    I usually settle on 0.004".
  3. Gurryman
    Gurryman Captain
    Sep 6, 2012
    1,026
    545
    New Bedford MA
    Nauset 28, CuttyHunk 28 Molds
    .001" for each inch of flange diameter. I usually get them under .002"
    Kailua Kid and Blitzen like this.
  4. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    Gotcha. I think a ZF 63a has a 4" diameter flange...
  5. ARC
    ARC Senior Member
    Sep 30, 2017
    230
    156
    All are in agreement. That’s a first
    ARC,
  6. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    It's getting lined up this weekend...
    Genius likes this.
  7. mike@mpi
    mike@mpi Senior Member
    Sep 1, 2013
    283
    106
    stevensville, md.
    26 JC
    Center your prop shaft in what ever stuffing box or shaft log you have coming through the hull into the engine room. In my case I have a 2" shaft tube and 1.5" shafting so I centered the shaft using four 1/4" strips of rubber. Set the gear output flange so it's right in line with the shaft and then pull the prop shaft up onto the transmission output shaft pilot. When it's close enough to easily measure with a feeler gage you want to set the flange face to face tolerance to .001" for every inch of shaft diameter plus .002" built in tolerance. Basically if I have 2" shafting and it's flange deviation is .005" or less it's going to be OK. I just don't want the whole engine/gear package offset to the side or up and down enough that it's stressing the prop shaft seal.
    Kailua Kid likes this.
  8. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    I got Up and Down and Left and Right between .025" and .003". I am going to try to get it a little more closer in tolerance...
    Kailua Kid and Toolate like this.
  9. Toolate
    Toolate Captain
    5,541
    1,577
    Building contractor
    Rotate the shaft 120 degrees and do it again. Then do that again so you have checked it 3x in 3 diff positions.
  10. Diesel Jerry
    Diesel Jerry Captain
    Oct 25, 2015
    4,095
    2,066
    Not to be captain over achiever but if you get it in spec don’t just stop there. Get it as close to perfect as you can.
    Kailua Kid and powderpro like this.
  11. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    Okay
  12. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    What?
  13. Diesel Jerry
    Oct 25, 2015
    4,095
    2,066
    Lets say you have a 5” coupling. Don’t get it to .004 and just stop. Sometimes with a little patience you can get it to .002 or better.
  14. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    Understood. Thanks.
  15. Toolate
    Toolate Captain
    5,541
    1,577
    Building contractor
    Are you a “check it again in the water” type of guy? I have done in a few times and not seen any difference so I think I am over it but if I had an old/flexy boat I would probably do it.
  16. Diesel Jerry
    Oct 25, 2015
    4,095
    2,066
    In most cases yes. I do a lot of sail boats here and you wouldn’t believe the change from no mast to mast that is fully tuned. Some don’t change. All depends on how the boat is built. How the boat’s block and stands are.
  17. Genius
    2,357
    1,139
    ....then you start your engine that sits on soft mount and your alignment goes to sh#t.
  18. Diesel Jerry
    Oct 25, 2015
    4,095
    2,066
    It is funny to see an engine move around, then you start to wonder why was I so anal.
    Kailua Kid and Genius like this.
  19. toolmaker
    toolmaker Senior Member
    Nov 13, 2013
    204
    87
    Patrick
    ---everything that the boys have stated is great info, BUT lets never forget the machining accuracy of the couplers themselves and the shaft and keyway. When I built my last twin screw Carolina boat a few of my incoming QC inspection holds were on these specific components [learned from previous nightmares] and both were found to be no where near what I considered even close in my world. Everything was boxed up and air freighted to my shop and reworked to perfection; makes assembly and alignment a heck of a lot easier and accurate with minimum drive line vibrations due to excessive individual component tolerances as a result of manufacturing sloppiness and no accurate inspection.
    Always a lot of variables to deal with of course when setting up the drive line.
    Jay
  20. PatrickPresti
    May 2, 2013
    710
    54
    Islip, NY
    Jay,
    I totally agree. Before I removed the engine, the boat ran smooth and was vibration free. I am still using the same gearbox, shaft, and couplers so I know it wasn't an issue beforehand. I will keep you posted with how I make out. Thanks for your suggestions.
    Pat
